2023 Toyota Sequoia with Level Kit and 35" Tires
supersix
31
2023 TRD Pro Sequioa looks amazing with the Westcott Designs level kit. It brought the front exactly 2” in the front. Which left a nice 1/2” rake back to front. Perfect! The ride is super plush! No trimming is needed and no rubbing anywhere. 35x12.5x18 on the OEM wheel.
Bishop
8
2
Your mom's house
Here you go. No rubbing as of yet. Will update again tomorrow.
Picked up some Dobinson rear springs. Just waiting on the Kings to arrive.
Hyrepower
Las Vegas
Do you have any pics of your ride after the Kings and springs? How is the ride quality with the new setup? I was thinking about either doing the Dobinson 2” front springs only, or going all out with a full set of Kings and running 35x12.5x18 tires on the OEM Pro Wheels. I also wondered if your 35x12.5 BFG KO2s rubbed when it was stock height, if not, then I may just go with the Dobinson 2” lift springs which apparently give the TRD Pro 1” lift. I wouldn’t mind keeping the stock suspension and trying to keep the ride as plush as possible.
Whiskeyranch20
2
Castle Rock, CO
Just FYI, 285/70/18’s will fit just fine on the stock height. They come out to 34.8 with zero rubbing. I had some Fuel Off-road Blitz wheels with Toyo’s from our 21 Tahoe that we traded in. Luckily same bolt pattern just needed to buy hubcentric adapters. The Fuels have a more aggressive offset. I love a little poke. Still deciding on the leveling kit. I want it but my wife doesn’t. 🤷🏼‍♂️ Her ride so…
Top
