Engine code p2714, VSC lit up
sixmenn
2
Michigan
My 2005 Sequoia Limited started shifting strangely after my radiator blew out internally, allowing the transmission fluid and coolant to comingle. I've replaced the radiator, and flushed the coolant system. I've also drained out the transmission pan, replaced the fluid with 4 quarts, then pumped it out (did this 4 times until the transmission fluid looked like new). But I still have code 2714, and it still shifts strangely. Apparently it's a fault in Solenoid "D" being stuck OFF. Any idea how to access this solenoid? I believe it can be accessed by removing the drain pan, but there are a number of solenoids in there. Can someone point me in the right direction?
Thanks!
Top
